Front Brake Nightmare
OK well today i figured id replace my front pads on my 96 road king since they were squeaky and didnt stop so good. So i replace both pads on both sides seemed simple enough , put it all together and the brake lever goes basically all the way to the grip without much resistance. So now i start to panic try to bleed the brakes , get nice steady squirts of fluid out of both bleeder screws BUT the DAMN LEVER is still soft and the brakes barely work. If you watch the piston in the caliper while you squeeze the lever you can see it barely moves
HELP
HELP
Received 4,361 Likes
Just cut the zip ties.
Don't mess with the bleeders.
The purpose of having the lever 1/2 way open is to let all the tiny air bubbles float to the top.
Sometimes tiny air bubbles get suspended in the brake fluid and that causes problems when you go try to bleed your brakes. By leaving the leaver 1/2 way down you give the air a place to escape.
