reman engine program discontinued?
Everybody should know good-n-well that the EVO powered FXR's they produced after the TC introduction and the dropping of the EVO....was simply a marketing technique to use up all the EVO parts they had and that carried through with the reman program. They finally ran out of EVO parts and don't likely plan to manufacturer anymore. Praise-the-lord for the aftermarket folks!
If the state requires tracking of engine serial numbers, the engine serial number will be on the registration along with the vin.
The numbers on the bike must match the numbers on the paperwork, but the numbers on the frame and engine have never been required to match.
No states require the numbers to be matching between the frame and the engine. Harley is probably the only automotive manufacturer that actually uses matching numbers.
I sold a bike to a guy in Monroe, Louisiana and I thought they were going to make me come over for a blood-test or something before they finally gave the poor guy a tag and title.
My state of residence doesn't care, for the time being at least. As long as I have a Bill of Sale that is witnessed by two people (maybe one of them could even be my cat for all they know), and the transferred title....they will issue you a tag and title.
Originally Posted by Tee⋁13030355
What's a long block? No carb, no intake, no ignition. What else?
That would be it. As I said, they used to sell that as the "smart start" engine program. Currently any reference to that appears to have been removed from the H-D website. Until I see proof otherwise, I have to assume that Harley is no longer selling engines at all, remanufactured or new.
in addition to the absence of parts TV states, a long block from harley would not include the covers (rocker box and timing)... and from what I read, no cam, lifters, or pushrods either
Received 4,361 Likes
I went that way several years ago! We even get the choice of an Evo or TC that will fit our Evos. My 107" is just fine, with a 585 cam in it, but they do a low CR 124" with that cam now......
true, texashillcountry... i don't begrudge harley for moving on
and yes, S&S cases are way better, no doubt... for some reason, I just wanted to keep it "harley" ....but now that I got the S&S coming i'm very happy i made the move... the indy that does the work i don't have the time or tools for was very pleased....he's gonna press out crank from stock case half and install it in s&s and bolt it all up
i could have got a harley crankcase, but they come with nothing ...no bearings, seals, studs or case bolts...just two halves ...the s&s comes with all that stuff, and it's beefier, too
Why in the hell would they care? The VIN on the frame is all that matters these days unless it's an old slabside shovel that doesn't have the VIN on the frame, just on the motor. If the license plate and VIN on frame match up to you I can't see it being a big deal. What if you slapped S&S cases in your bike?
If you get pulled over by the CHP, and the numbers don't match what is on your registration, you've got big trouble. Your bike will probably be impounded until you can prove ownership of the different engine.
During my recent FXR rebuild, the only reason I exchanged my original cases for brand new Harley cases was to keep the same engine number. If I had bought S&S cases or Delkron, my bike wouldn't be a Harley anymore.
