tappet block bolts ?
Old 07-13-2014, 05:30 PM
machinehed's Avatar
machinehed
machinehed is offline
Default head bolts are 12 point.
Originally Posted by texashillcountry
Head bolts are 12 point.
Thank You Texas for that correction .
I was referring to the other small 1/4- 20 engine bolts that secure everything except the damned tappet blocks that are oem 1/4- 12 point ?!
Im in Canada and apperantly we dont have any 12 point sockets here ?!
Im going to replace the oem screws with other .
This $ 3.00 socket crap has held me up for three weeks .?!
Old 07-13-2014, 06:28 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
If you want I can mail you one of your choice.
Hell any thing you can't get locally is easily mailed.
Just ask Spanners.
BTW it wasn't meant to be a correction but more of an observation.
Old 07-13-2014, 06:33 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 48,988 Likes on 17,898 Posts
Amazon.com to your door, get 90% of my orders within 2 days . Some people are hard headed about the little ****............
Old 07-13-2014, 10:48 PM
Owtlaw's Avatar
Owtlaw
Owtlaw is offline
Originally Posted by nh-rider
I found 1/4" drive, 1/4" 12 pt socket at Sears when I had needed one. They also had the 1/4" 12pt box wrench.
Come to think of it, I think all box wrenches are 12 pt. Have one of those?
Old 07-14-2014, 05:47 PM
machinehed's Avatar
machinehed
Sorry for showing the frustration here but Man , what a pita for simple bolts .
Could use a simple box wrench but not enough room .
Gave up trying to find a simple 12 point socket after visiting every supplier here and even flagging down a Snap On truck ., no go .
Have purchased a set of stainless socket head bolts to replace the oems.
Will try that next.
Old 07-14-2014, 05:52 PM
johnjzjz's Avatar
johnjzjz
johnjzjz is offline
Received 4,849 Likes on 3,018 Posts
if you pm me your address i will put one in the mail to you tomorrow
Old 07-16-2014, 05:32 PM
machinehed's Avatar
machinehed
Default Give up on the canadian mystery 12 point socket hunt.
Thanks johnjzjz , found a bolt supplier here and picked up some 1" and 3/4" long 1/4 20 stainless socket head bolts . I had to purchase both lengths to try to fit as the oem Harley bolts are 7/8 " long and apperantly that is a big head scratcher for the industrial bolt suppliers .??? Go figure with that one as i suppose Harley just has to be different etc. etc.
I even tried purchasing ss washers to fit the countersunk tappet block holes to just make things a little better with torque readings etc. but No Way , they are not available . What a pita for us Canadians here in no parts land.
Im getting to old for this **** ., at least we have good beer .
Old 07-16-2014, 06:42 PM
texashillcountry
Dirt don't hurt
If you want to use those bolts just put a 1/4-20 nut on them and cut off 1/8". When you take the nut off it will clean your threads. Use the 1" bolts by the way.
I recommend you use a grinder to put a chamfer on the end before you take the nut off.
Old 07-16-2014, 06:50 PM
machinehed's Avatar
machinehed
Default bitch bolts
Will do .
Old 07-16-2014, 07:55 PM
Blue SOG's Avatar
Blue SOG
Blue SOG is offline
I've yet to get into the evo motor but my Pan uses a bastard 1/4-24 thread. Not easy to find. UNC is 1/4-20, UNF is 1/4-28... Harley opted for the 1/4-24. Thanks, HD... I don't remember what my shovels were...
Quick Reply: tappet block bolts ?
