ring gear play
ring gear play
After reading in another thread on this forum that someone had finally found the source of his evo shake I examined my primary and some of its components. I found a very slight play in ring gear but absolutely no playvin clutch hub. I took up slack in chain and all seems well. Some piece of mind developed and I closed her up.
the clutch hub is fixed to the transmissions mainshaft with a nut and can not move unless installed incorrectly
the outer shell ( ring gear ) is held in place with a ball bearing Via a snap ring - play can develop in the ball bearing and OR the snap ring groove - play = worn out bearing
adjusting the chain tighter than normal to eliminate play -- if thats what you have done will wreck the teeth on the back of the ring gear ( starter gear will hit it at an angle instead of straight on ) and cut deeep grooves in the plastic adjustment shoe
little known item - the primary chain gets tighter as the assembly gets hot and expands after 45 min of driving
Mine does not move like yours and the rivets are tight however I took clutch apart and with the hub still on tranny shaft via nut the inner hub when rotated by hand moves in and out. i will post video in a day or two travelling now but i have video but cant post on mobil3 site any videos or I dont know how.
JustDave71
44
04-14-2010 12:32 AM
goldwingowner1983
09-15-2009 08:29 PM
