early 1984 cylinder head bolts?
the online manual cylinder head image shows head bolts 9-13 for late 85 with washers which I have? it appears early 84 did not have washers? or am I reading it wrong? or did both 84-85 use the washer? were these ever upgraded? also I know its a good idea to replace head bolts on a rebuild for they stretch anyone ever reuse these?
3 different head bolts were used on the run of evo engines
very early the bolt has a thick washer and IT IS a male bolt on the end - screws into the fat top head female block stud < this is the odd one
second HD idea a male engine block stud PUT in UP SIDE DOWN / and a female bolt with a thick washer
third idea / and they forgot to tell everyone to turn the studs over // is a female bolt the correct length this time so NO washer is needed on all 4 bolts on each head
what us it your trying to do and no the studs do not need to be replaced
bolts
Just curious I hear different things,Im rebuilding the bike wondering If I can use different studs and head bolts the head bolts that are female end
the ones you have have no bubble on the stud correct
torque
Yea Ive had that happen a good mechanic told me to make sure there is no oil in the female end he said some people use oil on the threads it causes air tight seal to build up and can give false torque.he told me to use anti seize on threads to get good torques and I have had great success using it
bolts
I was just given the wrong information by James Gaskets and didn't torque them to the final torque value since I didn't have the sheet they send with their gaskets. I made sure to get the excess oil out of the head bolts so they didn't hydraulically lock and give me a false reading or tearing anything up.
I hear ya man, I learned many lessons over the years how important torque values are Dont give up on james though they make great gasket kits I only use their metal gaskets.paper just doesn't cut it with me.I will probably replace my head bolts and leave the studs alone EVO studs tend to get striped in the case sometimes don't want to mess with them
