Tranny problem
Well to be honest I haven't looked at it yet. here what going on riding hard down (85 +mph) the highway everything seem fine when I got of the exit ramp it hit phantom neutral between fourth and fifth gear didn't think much of it. Till I was siting at a long *** light tried to get neutral from first the shifter was hard to shift (didn't get neutral) drive off shift seem fine I get home shut the bike off still hard to find neutral I'm able to shift with hand. Had to go to movie with ol lady came back four hour later I was able to shift into neutral like all is well. From what. Could tell it wasn't binding up ( the shift linkage) and idea. I think spanner might know all about tranny lol it's a 96 softail with lil over 3" ultima belt primary. (Sorry spanner had to throw in a tranny joke you crazy sob lol)
Okay tried adjusting it. I don't know if adjustment of cable different for open primary or not but. It seems to feel good but riding it take forever to disengage almost all way out? Probly did it wrong. Also on ultima open belt how can you adjust the clutch pack (probly wrong word) lcan it be done like normal clutch I didn't install this so it's all new to me. Does anyone have a PDF service manual for 96 flsts well I'm off to work
To adj the clutch, first give slack to cable so lever is loose about 1/4 inch. then on clutch pack loosen center nut, then just snug up center pin, then squeeze hand lever 3 times. then back center pin 1/2 turn, and then tighten lock nut about 15 lbs. Then adjust lever cable to where you have 1/8" slack where cable sheath goes in lever housing. Done.
If slipping and cant adjust it out probably need clutch plates. The middle spring plate is well known for falling apart. If you replace clutch plates " do not" put the spring plate back in. Barnett and Energy One make great plates without the spring plate. My new Energy One plates cost about $110 to replace both steel plates and fiber plates and pressure plate. Do not use any old stuff except the basket is probably still good.
