Tranny problem
Old 06-14-2014, 07:08 PM
Rabbito's Avatar
Rabbito
Rabbito is offline
Originally Posted by Slammed-N-Senseless
Is fith the only gear it slips in?
What I can tell is fifth gear only and it random I will try to adjust the clutch itself.
Ace is it the way you said it couple post ago to adjust a open primary. Thank gentlemen for your help
Old 06-15-2014, 08:36 AM
aces&8s's Avatar
aces&8s
aces&8s is offline
I never had an open Belt primary but I would think the clutch adjustment would be the same.
Old 06-15-2014, 09:45 AM
Rabbito's Avatar
Rabbito
Rabbito is offline
Yea did some searching and looks the same it thanks man
Old 06-15-2014, 12:36 PM
Rabbito's Avatar
Rabbito
Rabbito is offline
Ace here a video of a sound it's making in first gear with clutch pulled in any idea
Edit update I took ace advice adjusted clutch took out for a ride. It seem almost 100% no slipping that. Could tell the alone question is that clicking sound in gear with clutch pulled in
Old 06-15-2014, 02:49 PM
aces&8s's Avatar
aces&8s
aces&8s is offline
In first gear with clutch pulled in you should get a little noise when rocked but yours sounds a bit loose. Don't know if that's because of open primary though.
Old 06-15-2014, 03:11 PM
Rabbito's Avatar
Rabbito
Rabbito is offline
Yea I don't know. Hopefully someone who has a open primary could tell me
Old 06-15-2014, 03:27 PM
aces&8s's Avatar
aces&8s
aces&8s is offline
Now that you have it pretty well adjusted, if it keeps giving you problems or gets to not shifting, you might consider new plates. A bad spring plate just gets worse.
$110 buys all new plates plus you will get to see if anything else is going. Basket usually still good. A bad spring plate can shed metal rivets and screw up the basket if not attended to but usually it will be very hard shifting before anything happens.
Old 06-15-2014, 03:43 PM
Rabbito's Avatar
Rabbito
Rabbito is offline
Now that you have it pretty well adjusted, if it keeps giving you problems or gets to not shifting, you might consider new plates. A bad spring plate just gets worse. $110 buys all new plates plus you will get to see if anything else is going. Basket usually still good. A bad spring plate can shed metal rivets and screw up the basket if not attended to but usually it will be very hard shifting before anything happens.
Ok thanks I'll keep this in mind and be on look out for clutch plates thank man
Old 06-15-2014, 03:59 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
Open primaries make some odd noises for sure, some jingle when running in neutral.
Old 06-15-2014, 07:03 PM
Rabbito's Avatar
Rabbito
Rabbito is offline
Yea it was a surprise to me when I seen and heard this for the first time lol
yzergod
06-11-2013 08:46 AM
Cycopath
05-15-2010 06:41 PM
hogrider09
04-17-2010 06:43 PM
michaelbarry
03-30-2008 08:20 PM
glebo
08-07-2007 08:58 AM
Quick Reply: Tranny problem
