Headlight acting weird
Old 06-03-2014, 05:49 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
Originally Posted by Uncle G.
That's the odd thing. Mine would only act up when the bike was first started, too. Never DURING a ride. In any case, it's something to check and costs nothing but a bit of time.
I didn't think it would fix my bike either, for the same reason, but it did. Sometimes logic doesn't seem to apply when hunting electrical gremlins in a Harley.
I'll give it a try.
Thanks
Old 06-03-2014, 06:12 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
Originally Posted by texashillcountry
That part I get but why only when it is cold?
That's just the way it is....the connectors and wires run warm so expand when they have been used for a few mins.
Old 06-03-2014, 07:33 PM
jimbo285's Avatar
jimbo285
jimbo285 is offline
Take a voltage reading at the headlight socket in the morning and see if you have a pulsing.
Old 06-03-2014, 07:41 PM
Proud Marine Dad's Avatar
Proud Marine Dad
Proud Marine Dad is offline
A couple years ago I had a similar problem. I'd start up the bike, and no headlight. Take it apart and try the bulb-worked perfectly. Put it back together and it would be fine until the next time it acted up.
What fixed mine was removing the contacts from the connector inside the headlamp shell, squeezing the contacts a bit tighter with some pliers, and reinstalling them. Apparently, the contacts weren't making good connection with the tabs on the headlamp all the time. It seemed to happen when I'd first start the bike for some reason.
Since I did this, I've had no more trouble.
Had the same problem and did this to the RK. Headlight would flicker only after the bike would sit overnight. At start up in the morning a good smack to the headlight bucket would stop the on and off for the rest of the day. Squeezed the contacts tighter and didn't have the problem again.
Old 06-27-2014, 07:16 PM
texashillcountry
Dirt don't hurt
As a follow up I did as suggested above today.
Headlight now seems to work fine.
Of course while taking off the headlight it slipped out of my hand and went bouncing across the garage floor.
I wonder if that helped any.
Old 06-27-2014, 07:38 PM
traildog's Avatar
traildog
traildog is offline
What the?????????? I don't think so........
Iron_Bandog
Electrical/Lighting/Alarm
07-26-2014 07:58 AM
transdel
07-17-2013 10:02 PM
scooter34
05-29-2009 04:00 PM
blueglide88
EVO
08-14-2008 02:55 AM
skullandcircle
09-15-2007 03:31 AM
Quick Reply: Headlight acting weird
