Leak at the cases
Leak at the cases
guys, need a little help here...i noticed a leak where the cases meet on my EVO. it looks like theres a type of sealant hanging down? what would be the fix for this? Split the cases? or can I just clean up real well and re seal? if so, what should i clean it with? Brake fluid? and what should i use to re seal it? I've never split the cases on an EVO before...thanks
If you do dig into it,
Loctite 518 is the best there is for sealing engine cases, it's also anaerobic.
Yamabond or that silicone looking stuff harley uses does not even come close(hence your leaking cases)
http://www.loctite.com.au/3320_AUE_H...ID=10000009R65
