Starter install question on 1986 flhtc
I am going to replace my starter assembly, not just the motor I think they are built as an all in one unit. I wanted to know if, on my 86, do I have to remove the clutch basket or is it two bolts and I take it out?
Just wanted to know what I have to look forward to
Thank you
Thank you
If it is anything like mine, a 90FLHTCU just remove the outer primary, bend the tabs back on the star bolt and undo the bolt. Move to the other side of the bike, disconnect the + from the Batt, then from the starter. Remove the blade connector wire and the two mounting bolts with Allen heads. Unless it is braced to the exhaust cross-over it will pull out now. Reverse for install. This is rated at a 4 beer project at average temperatures, 60' to 88' when a garage is used. If any friends help multiply beer difficulty factor by 6 per person assisting. Hope this helps.
You have the Hitachi style starter. The starter motor and the reduction gear assembly are two distinct units. There's no reason to replace the reduction gear assembly unless there's something wrong with it, which ain't likely. The starter motor it's self sould come right off. The newer reduction gear style starters require more work as the whole thing is in one unit.
