broken bracket question
There are two brackets that mount near the top of the heads that also bolt onto the back of the AC assembly. My rear one broke and I'm wondering what the proper name of this bracket is and is it crucial? It seems to be pretty solid still but...? Oh yeah, it's on a '90 EVO w/42mm Screaming Eagle Mikuni.
Thanks
Thanks
the bracket you have holding the back of the air filter to the cylinder head has broken is my guess
yes you need it - and i am sure they are available from mikuni
what we do is to go to Lowes and they sell strap steel in one foot lengths it is a bit thicker so it will be stronger - bend the step drill the holes - make two of them and than paint silver or black install and forget it -- jz
Can anyone tell me the part # of the bracket in the top pic? I can not locate it in the schematics.
The ones in the picture are from jp cycles, there aluminum, I really wouldn't use those.
Found you some oem brackets 29208-87t
http://www.ebay.com/itm/Harley-David...-/291006432894
