Another Idle Speed Adjustment Question...
I just got through reading the other thread regarding idle speed adjustments and now I'm wondering about mine. I have a carburated '97 Road King. When I bought the bike and you started it up cold with the fuel enricher pulled out, it would idle at around 600 rpm until it warmed up then it would jump up to 1100 rpm...at which point you push the enricher in and it would drop back down to about 600 rpm. I bumped the cold idle up to about 800 rpm and my warm idle is about 925 rpm now. Is this still too low? The guy I bought it from said he liked the way it sounded at lower rpm but it's my understanding that this is not good for the engine. I figured I'd see what you guys thought about the matter...Thanks!
I had a Heritage with cams and all sorts of goodies. I left the idle where it was when I bought it which was low.. It sounded really cool but, I now know it wasn't very good for it. If I had it to do over I would turn it up a bit. On my 1988 EG the charging system isn't doing anything useful till about 1000 RPMs.
There are various jolly good reasons for maintaining the book rpms, of which charging and oil pressure are two. However the main one is mechanical. If engine speed slows too much, the crank is accelerated when one cylinder fires, but slows as the other one reaches compression, then accelerates, slows, etc. That is where the damage John mentioned can come from. Book idle speed enables flywheel momentum to even things out, to prevent that cyclic crank speed.
