New one 4 Me, any thoughts
In some traffic & down shifted to 4th, missed 4th down shifted again & hit 3rd, Up shifted to 4th then back to 5th. Thats never happened b4 so I tried it again at the next off ramp and the same thing happened. Pulled over bought some Beer and it seems Ok now. Now I know everything is better after some Beer but what would cause the Bike to miss gears like that? Do seem to have some play in the linkage but has Never been a issue,
I can't say I've had exactly the same thing, or maybe so. On a lot of bikes that I have owned I have occasionally found a sort of false neutral between various gears. The HD transmission is so clunky that finding the occasional "missing gear" seems normal. I'd do the same, beer, not worry, etc..
The dog teeth on the 4th gear pair may be getting worn and not locking in. I know it's hard in forth but just make sure you get full clutch disengagement before shifting this will allow the mainshaft to slow down and prolong the dog tooth life. It sucks babying it but it sucks tearing it apart and replacing gears to. If it only happens once in a while you still got time.
Received 4,361 Likes
Mine does that occasionally too.
If I'm shifting easy then it doesn't happen but if I'm shifting hard (high in the rpm range) it will do it almost all the time.
I don't worry about it.
+ 1 one the adjustment that could very well work
we have also found a few things that add to the miss shift or no gear when your on it hard usually 3rd --
First thing we look at ---- the 2 bearings in the door on the R/S are 3 point bearings and after 30,000 miles start to get loose, and they are not radial load bearings, they are the straight up type, soo in the aftermarket they have 5 point load bearings < OK what do they do different - the 5 point unlike the 3 hold the 2 shafts and do not allow them to walk - counter and main shafts solid < soo when you are shifting and the shafts that are normally held in place and are allowed to walk, - it misses gears -- we install 5 point bearings in the door - fix one
fix # 2 -- we use the baker shift lever spring assembly and the baker shift drum sure its expensive BUT not really if you have a big power motor, and go hard through the gears - ( missing gears at 6500 RPMs is a no no ) when you shift it its in the gear you select and all neutral issues are GONE - i really like the way it works and every bike the shop owns has one if they make it for that bike ---
oil also plays a part --- johnjzjz
Like THC I don't worry about it.
