2 Into 1 Exhaust vs. 2 into 2
Just some stuff I found while researching. If anyone would like to add their experience this could be an interesting thread.
From "Fix My Hog":
Dual exhaust Vs. a 2 into 1
Tags: Exhaust
AND:
From "Fix My Hog":
Tags: Exhaust
What is the difference between a dual exhaust system and a 2 into 1system in relation to why a 2 into 1 provides more power?
It really depends on how you define power. A lot of information available boasts peak power numbers, these numbers are usually at an RPM range that most bikes rarely see. To really understand how a system performs you need to look at a Dyno graph all the way through the RPM range. There are a lot of factors that affect where a pipe makes power. Engine size, compression, cam timing, cam overlap, valve size, and intake size are all part of the equation. The biggest factor to consider is at what RPM range the bike will be ridden at consistently. The fact is that pipes designed for race bikes, which are ridden in a very narrow high RPM band, will not perform on a street bike. A general statement that can be made is; longer smaller diameter pipes make low-end power and shorter large diameter pipes make top end power. One other design constraint to remember is styling. Everybody has his or her own opinion on what’s going to look good on his or her motorcycle. Drag pipes just wouldn’t be drag pipes if there was a collector stuck on the end of them. With all of this in mind, there are a couple of fundamental differences between 2:2 and 2:1 exhausts when it comes to design. The advantage of a 2:2 is that the pipes are separate so the length can be fine tuned for a specific power band. You can also tune each pipe length per cylinder if necessary. Also, you have far more styling latitude. The disadvantage is that the power band is narrower. The advantage of a 2:1 is that you tie the cylinders together giving you the ability to take advantage of the natural scavenging affect that occurs between the cylinders during the intake and exhaust valve cycles. This tends to give you a far broader power band and greater overall performance.AND:
Bonneville, Dyno, & Track Proven THE MOST POWERFUL SYSTEM!
If you want to make power on a multi-cylinder engine you have to use a collector system. Whether it's a V-Twin or a V-8 it's the same, and no less an authority than the famed engine builder Smokey Yunick will tell you that. Not using free exhaust energy to help your engine breathe is downright criminal. No matter what the conventional wisdom is, staggered duals on a Harley will not make more power. You simply cannot escape the fact that a properly designed 2-1 will give you more useable torque where you need it, in the 2000 to 4000 rpm range, which means less downshifts and less rpm to get the job done. A set of short staggered duals at peak rpm can be made to produce good power but they will be dead on their *** until they get there, whereas an engine developed around an LSR 2-1 exhaust can be made to perform from the bottom up with no dips in the torque band!
Received 4,361 Likes
No argument here.
My understanding has always been that a collector type system will provide a broader, flatter torque curve, and "might" give up a few hp at the upper end of the rpm range when compared to a dual system "of the appropriate length and diameter".
Basically, duals are for the track and single is for the street, and even that could be argued, depending on the R&D put into a specific design.
Nothing that already wasn't said, was just telling it how it's always been told to me
All that being said, I think sometimes it comes down to splitting hairs over a few lbs. of torque/few extra ponies. A well designed dual system w/ an integral crossover (vance&hines big shots) have put up numbers close to popular 2-1 systems. My .02
They are some really sweet pipes, though. Just a little too rich for my blood...
A simple example of the benefits of a 2-into-1 are the Buell models. By using equal length siamesed pipes Buell was able to raise the level of tune the stock engines are built to, with higher CR and more aggressive cam profiles, producing a wide torque range and much bigger numbers than a Sporty. In addition the bikes also meet the same EPA regulations.
My own experience, with my S&S 107" engine, involves a set of true duals (Samson pipes with S&S oval mufflers), which I later changed to a Supertrapp Supermeg 2-into-1. The reason was simply that I got fed up with the left pipe of my TDs resting on the top of the primary! I had my bike set up on the dyno for both, by the same shop and operator.
The headline figures for both are similar: TD 103HP, 102TQ; 2-into-1 101HP, 107TQ. However what those numbers don't show are the gains in low/mid range torque of up to 15%, between 2,500-4,000 rpm, where most of us ride. In addition the engine is far smoother running with the 2-into-1 and a much nicer thing to ride. So there are measurable benefits, plus tactile ones!
Clean and dirty:
Clean and dirty:
Haven't had time to run it yet though..
