Dieseling ???
Received 4,361 Likes
I have been using pure gas at 90 octane and premium with a shot of startron. I was wondering if I might have carbon build up causing hot spots. Thought Id try the old trick of getting the engine up to operating temp and then spraying cold water into the carb to break up carbon deposits..??
You can't read plugs anymore with this ethanol crap... my bike has the PERFECT amount of decel pop, no surging on decel, no coughing or spitting once warmed up, no pinging, but the front insulator only shows one spot with a little tan on it... no black spots or ***** of aluminum.
My bike is running stock compression, but if it's really hot after a good run, it will diesel. Out of 10 shutdowns, it will do it 2/10 times... I'm not really worried about it. I've run 93, 89... it seems that it didn't start doing it until I put in 89, but at stock compression, with a v-thunder 3010, it shouldn't need 91/93 octane.
