Item # 3 in the service manual. I cannot remove the cap. The fork is clamped in a vice and when I try to loosen the cap the fork turns. I have put a cheater bar on the vice to make it good and tight, but it still turns. Any advice? thanks
Had a seal weeping and decided to upgrade with Progressive springs. The fork caps are tough to get back on. Other items, new tires, pack wheels bearings, Progressive touring link, already have the Glide Pro bushings, brass fuel inlet on the carb, new ignition, brakes, check electrical connections, torque bolts, new exhaust, checked the neck bearings and new grease, new lights on the fender tips, new tail light, and deer whistles. Peace of mind and therapy.
