Tank not venting
Old 03-09-2014, 12:45 PM
bluharley's Avatar
bluharley
bluharley is offline
Default Tank not venting
I've noticed the last few times I park after riding, my yank is building with pressure, I have to pop the cap to relieve it. Is it just a simple wire poke to fix that? Makes me wonder why it's plugged. Since I had to seal the tank due to excessive rust when I first got the bike, I'm wondering if my sealer is degrading and floating loose. Sad thought, but like I was told, it's just a matter of time before it.........
Old 03-09-2014, 12:54 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
Can you get a vented gas cap for your model?
Old 03-09-2014, 01:00 PM
bluharley's Avatar
bluharley
Hmm, good question. I think it is a vented cap, at least it looks just like the vented caps for cars I've always seen. Maybe I just need a new cap if I can find one.
perki48's Avatar
perki48
perki48 is offline
Received 4,406 Likes on 2,029 Posts
Did you seal it with that cap on? If so you sealed the vent.
Old 03-09-2014, 01:12 PM
bluharley's Avatar
bluharley
No, I didn't, but that was a long time ago and I would have noticed. I just looked at the cap, and it looks fine. The little spring loaded vent pushes in and springs back out. I can't imagine what I never noticed it before, but maybe it's been hissing forever. I was just wondering about that little hose fixture that sticks out of the tank there. Never new what it was for. Maybe I'm just looking for a reason to complain.
Old 03-09-2014, 02:01 PM
usraptor's Avatar
usraptor
usraptor is offline
Since you live in Florida, I'm not sure if this applies. But I had a similar problem with my Heritage that I purchased in Calif. Ended up the charcoal canister that the tank vents to was plugged. I just disconnected the vent tube from the canister and let it hang open. Problem solved.
Old 03-09-2014, 02:09 PM
bluharley's Avatar
bluharley
No cannister on this old boat, must have been a California thing you had. Thanks.
Old 03-09-2014, 08:05 PM
aces&8s's Avatar
aces&8s
aces&8s is offline
Dealership has vented caps about $13. My tank has an air tube that out from under the tank at the front of tank by steering neck, try blowing thru it both directions.?
Old 03-09-2014, 08:11 PM
golfblues's Avatar
golfblues
golfblues is online now
Received 1,540 Likes on 932 Posts
If the sealer is degrading and loose I would think the motor would stalling or sputtering too.
Old 03-09-2014, 09:00 PM
highbarst's Avatar
highbarst
highbarst is offline
Had one last year with same problem an earwig had got inside the vent tube and died it blew out when we blew air from the top side .
Quick Reply: Tank not venting
