So, waht can happen if my cam chain is too tight.
Old 03-04-2014 | 07:50 AM
traildog's Avatar
traildog
Default So, what can happen if my primary chain is too tight.
Sorry I meant Primary chain.....
I went in to check the tension, and the chain was WAY too floppy.
I moved the tensioner a click, and now it seems too tight.
Did it several times, but couldn't get it "just right."
WTHeck?
Old 03-04-2014 | 07:56 AM
soft 02's Avatar
soft 02
Primary chain?
traildog's Avatar
traildog
Originally Posted by soft 02
Primary chain?
Yea, that......
Old 03-04-2014 | 08:00 AM
soft 02's Avatar
soft 02
So loose its slapin the case? Id go loose before I go so tight its wiping oit bearings. Loose and tight are subjective though. I ran into this with my Baker primary shoe and left it on the loose side and kept an eye on it.
Old 03-04-2014 | 08:06 AM
bluharley's Avatar
bluharley
It will whine and tear up bearings if too tight. The chain gets shorter as it gets hot, so loose is better.
Old 03-04-2014 | 08:13 AM
traildog's Avatar
traildog
Well, looks like I'm going back in tonight........Thanks fellers.
Technomama (07-14-2023)
Old 03-04-2014 | 08:14 AM
johnjzjz's Avatar
johnjzjz
take out the plugs - rotate the motor around counterclockwise using the 1 1/2 inch nut on the front sprocket --- couple inches at a time and majic mark in the center between the clutch hub and motor sprocket -- the tightest spot on the chain in the circle of turning - < that is the adjustment spot < adjust it so it has some ( some ) loose play up and down -
re do what you have adjusted and see if what was the tight spot stayed in the same place and it still has up and down free play == johnjzjz
Old 03-04-2014 | 08:35 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
That is one thing I never understood!!!
Things expand when they heat up and shrink when they get cold.
How can the chain shrink when it heats up?????????????
Oh and don't forget that with a chain too tight the adjuster shoe gets worn down faster.
Old 03-04-2014 | 09:02 AM
bluharley's Avatar
bluharley
Yea, it's not intuitive. All I can figure is the bearings and such inside the rollers expand and draw the chain links closer together. I can picture it in my mind, but the explanation will have to come from someone smarter than me. Maybe Spanners has an understandable explanation.
Old 03-04-2014 | 09:24 AM
hobobiker's Avatar
hobobiker
I don't have a manual in front of me, but there should be a measurement of slack that you're shooting for when adjusting. On Shovels/Pans I use a machinist ruler and shoot for 5/8 of an inch if I'm remembering correctly...
Quick Reply: So, waht can happen if my cam chain is too tight.
