So, waht can happen if my cam chain is too tight.
03-08-2014 | 12:09 PM
Quote:
Originally Posted by
HarDlife
http://www.engineeringtoolbox.com/linear-expansion-coefficients-d_95.html
What is this crap?!&@$##!+)$\)(:%;-0=!&)-)‘)+%!_)%(")"!%;¤(&_)_&))__
03-08-2014 | 04:49 PM
TD, since you went for a 50 mile ride and didn't note any whining, I'll assume it's not too tight, but did you check it when it was hoy?
03-08-2014 | 05:29 PM
bluharley
I absolutely forgot to. I was so giddy after the ride
03-08-2014 | 05:38 PM
traildog
You mean busy cleaning don't you??????????
03-26-2018 | 07:32 PM
Primary chain
bluharley
It will whine and tear up bearings if too tight. The chain gets shorter as it gets hot, so loose is better.
Actually, the chain gets longer as it heats up. Metal expands under heat.
03-26-2018 | 07:43 PM
clayguy
Obviously you haven't read your service manual.
BTW did you notice this thread is 4 years old?
03-26-2018 | 08:42 PM
I noticed the thread was 4 years old when I started, but now I'm 80 something posts in and I gotta know...did TD ever check the chain when hot???
03-27-2018 | 07:58 AM
hobobiker
I don't have a manual in front of me, but there should be a measurement of slack that you're shooting for when adjusting. On Shovels/Pans I use a machinist ruler and shoot for 5/8 of an inch if I'm remembering correctly...
Cold 5/8" - 7/8
Hot 3/8 - 5/8
This is most common for EVO's but check your FSM for your model.
I always adjust cold... after finding the tight spot I do 3/4" which is middle of the spec.
IMO too tight on the primary chain is the number one reason for a hard to find neutral.
03-27-2018 | 02:15 PM
clayguy
The chain may get longer as it heats up, but the primary case and sprockets are heating up, too, and they heat up and expand MORE than the chain.
rquest
11-01-2021 04:44 PM
Lars Engstrom
07-22-2019 07:05 PM
Rickr01
10-01-2013 08:01 PM
jpooch00
12-21-2012 08:24 AM
Paul32730
12-15-2007 10:43 PM
