So, waht can happen if my cam chain is too tight.
Old 03-04-2014 | 05:51 PM
aces&8s's Avatar
aces&8s
It's 3/4" deflection cold is the mid point of min-max for a 97 evo...
  #32
Old 03-04-2014 | 06:03 PM
traildog's Avatar
traildog
OK.....DAMMIT! I'll open her up AGAIN......just to make sure......
  #33
Old 03-04-2014 | 06:04 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Not sure why you are getting upset it ain't like your going for a ride anytime soon!!!
  #34
Old 03-04-2014 | 06:06 PM
traildog's Avatar
traildog
Originally Posted by texashillcountry
not sure why you are getting upset it ain't like your going for a ride anytime soon!!!:d
good one! You !#$@%(_&)*#&%*^$@#@$!@@^!&$@*^&^*@%$^~@#$!$~$#^&#% *$(^&#*@!#$%!#$%~#$&@*#%^&(#%%$#^%!#%@!^&%@*^#&%^% $#$^%!#~@^!#&@%*#^$#*@&#$^%@##~@$^!&$%@^#(&#%^$&%^ $@$~%^!#%&@*#(&#%*^$@&!#^@%!
  #35
Old 03-04-2014 | 06:08 PM
texashillcountry
Dirt don't hurt
Put down the seafoam..
You spelling ability has gone to **** !!!!!!
  #36
Old 03-04-2014 | 06:10 PM
traildog's Avatar
traildog
HEY! You can't say CHIT on a public forum..........
  #37
Old 03-04-2014 | 06:17 PM
texashillcountry
Dirt don't hurt
Why not???
If the mods thought it was a bad word they would have put a block on it like they have for other words.
  #38
Old 03-04-2014 | 06:45 PM
aces&8s's Avatar
aces&8s
That word is in the Tex dictionary.
  #39
Old 03-04-2014 | 07:11 PM
aces&8s's Avatar
aces&8s
I made this so adj pri chain is easy & quick. Set the steel bar on the shoe block and it touches bottom of chain. Set the 3/4"copper on top of the steel for your 3/4" measurement.
For storage, one fits inside the other.
Attached Thumbnails So, waht can happen if my cam chain is too tight.-img_0838.jpg   So, waht can happen if my cam chain is too tight.-img_0839.jpg
  #40
Old 03-05-2014 | 04:48 AM
Hopper's Avatar
Hopper
Originally Posted by Schex3x
I would think the aluminum inner and outer primary, and transmission housings is where most of the extra play is taken up.
Yep, Aluminum expands waaay more than steel. About double the amount. That is what I always figured caused the chain to tighten up when hot. You can see from adjusting the back chain on an older bike that it takes hardly any lateral movement of the hub/sprocket to produce and inch of chain slack up and down.
Quick Reply: So, waht can happen if my cam chain is too tight.
