Carb question for upcoming cam swap
OK, 97 FXD.
All parts are on the way, or already here. EV27 cam, SE coil, SE wires, S+S pushrods, Hylift lifters, SE ignition module (to be changed for an adjustable one later once pipes and headwork is done, maybe next year). What I have now is a stock bike with a KN filter, and long straight pipes that I put Big City Thunder baffles in.
I have never touched the carb. Plugs look good and it runs fine except for some hard starting when the temps get low.
I will replace the carb to manifold rubber and both seals. I also need to put in a new choke cable unless someone can tell me hos to replace the plastic adjustment wheel.
Now, I have three options. 1, use CV Performance innards, 2. install a Thunderslide kit, or 3. just rejet and adjust the mixture. In that I have just about used up my bike improvement fund for this spring, I think I may just rejet and adjust. Opinions on the other two options are welcome though.
Jets, Best I can figure I should begin with a 45 slow jet/pilot jet, and a 180 main.
Thoughts and advice of the board are appreciated. Thanks guys.
45 slow and 180 main should be perfect honestly. I put the CV kit in my bike.. have yet to try it out yet, but was running a 45 idle when it was stock, and the PO put in a 190 main jet trying to cure an intake leak and I didn't notice it when I put in the 45... stupid me. Anyways, the plugs were a little dark but that was it.
I would ship the CV off to Dale at Killer Cycle and have him rebuild it, polish and rejet it. Or, do a core exchange.
http://stores.ebay.com/Killer-Motorcycle-Products
