Where to find 3.1" Jiffystand Spring?
For some reason, my new to me used 90 FLHTC does not use standard HD Jiffy Stand Spring. That spring is too long by about 1/2". I need a spring that measures 3.0' to 3.1" hook to hook.
I have spent an hour googling all over the internet for this spring length with no results.
Right now I have the longer spring on the bike. I took the longer spring and hacked it down so it would put enough tension on the jiffystand to hold it up.
Thanks.
Thanks.
The shortest one i have in the shop is 3 .370 and they 1936 to 1984 --
i think < i think and i dont have one in the shop soooo / the dyna k stand spring is shorter but i am not sure - oem number is -50057-91 the correct one for that model is
50005-85A--FLHTC - but i have had that issue and found the china k stand in my case the tab was in the wrong spot so we $hit caned it and bought the correct one - jz
Received 4,361 Likes
I used this one, perfect fit.
It says it does not fit, but the oe number is correct.
http://www.jpcycles.com/product/7000051
