Rear spocket missing teeth
01-04-2014, 04:10 PM
Dirt don't hurt
I just changed the sprocket for a friend of mine that had 5 missing teeth in a row, then one good tooth, then 4 missing teeth in a row..
It is a chain drive with a 530 chain.
What causes this??????
01-04-2014, 04:11 PM
Don't think I've ever seen one that bad. Rocks? Crappy Chinese steel?
01-04-2014, 04:33 PM
Tooth fairy?
Probably not very helpful...
01-04-2014, 04:39 PM
Dirt don't hurt
Quote:
Originally Posted by
Dr.Hess
Is there any chance the chain stretched then rode up on the teeth and broke them off?
01-04-2014, 04:41 PM
Dirt don't hurt
megawatt
Tooth fairy?
Couldn't be!!!
The tooth fairy leaves money and my friend is broke as hell!!!!
01-04-2014, 06:26 PM
texashillcountry
Couldn't be!!!
Did it look kinda like YOU?
01-04-2014, 06:47 PM
Cheap nasty sprockets would be my guess. They don't usually break off until they are totally hooked and worn. If they snapped off and the remaining teeth have a reasonable profile I would make sure he doesn't fit that brand of hardware again....and tell us the make so we can avoid it.
01-04-2014, 10:21 PM
Definately sounds like way over due replacement. I wouldn't do anything less than replacing both sprockets and chain (along with a talk with your friend about pre-ride inspections and preventative maintenance.
01-05-2014, 06:23 AM
Is it a steel or alloy sprocket? Some bright sparks like the weight savings of cheap alloy sprockets.
