Fender to tire clearance
Hey Guys
Over the years someone had swapped out the front fender for a Fatboy fender. I was never crazy about the FB fender, as the front tip allways appeared to long to me.
So today I figured its time to give it a new look. I cut it back 6 inches from the front tip. Now the front half looks much like the softail slim fender on the front half anyway.
The next thing I want to do is rework the mounts, just re drill the holes, and trim off the excess that was used to bolt it up. My question is, what is considered a safe tire to fender clearance? I was thinking a 1/4 inch would be good. But hey, what I think isn't allways right. So opinions would be helpful.
Thanks Guys
Thanks Guys
I put a 21" tire on my RK and its tight, maybe not quite as tight on the bottom as the top which is about the 1/4 you're talking about. Havent had any issues yet. Seems the front and rear were tighter than the middle, have seen it the other way around, couldnt get the front down because the middle would hit, tires that are pumped up good dont grow much, imho you should be good to go.
Thanks Guys
As it turns out these Fatboy front fenders are tight at the top , on centre line with the forks. I was hoping this thing would drop down more than it is, but it is what it is. The max drop will be 3/4 inch, with 5/16 clearance. Not dropped as low as I want, but with the 6 inch chop off the front leading edge, and the 3/4 drop it is a major improvement visually.
Again, Thanks for your input guys.
