groaning sounds coming from primary...
Old 12-09-2013, 08:03 PM
elevenbravo78's Avatar
elevenbravo78
elevenbravo78 is offline
Default groaning sounds coming from primary...
The bike is a 86' FXWG, groaning sound only happens when letting out the clutch in 1st gear, it also lunges forward. If I continue to ride it, it seems to go away. Very hit or miss because I've had days where its happened two or three times. Then some days not at all. I adjusted the primary chain because it was loose once. that didn't stop it. I also adjusted the clutch as well. that didn't do any good either... I thought maybe Its possible the compensator isn't working properly causing the noise. I'll get into it tonight and go over the whole primary. Any other ideas?
Old 12-09-2013, 08:32 PM
Dr.Hess's Avatar
Dr.Hess
Dr.Hess is offline
Received 2,917 Likes on 1,430 Posts
Kinda sounds like the clutch is grabbing. Maybe you have no clutch material left on the plates?
Old 12-09-2013, 09:32 PM
Shaylex's Avatar
Shaylex
Shaylex is offline
Pull your clutch plates out and have a look. Sounds like they probably need to be cleaned.
Old 12-09-2013, 09:58 PM
Spanners39's Avatar
Spanners39
Spanners39 is offline
Your primary is haunted, you need to perform an exorcism....
Old 12-10-2013, 07:46 AM
falconbrother's Avatar
falconbrother
falconbrother is offline
I haven't a clue what would cause this but.. Please share when you figure it out. Thanks.
Old 12-10-2013, 08:24 AM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
I gotta agree with the Doc.
It sounds like clutch plates to me.
Old 12-10-2013, 11:02 AM
Jim Kraft's Avatar
Jim Kraft
Jim Kraft is offline
Does it do it with the clutch out, or just as you are realeasing it? Could be the clutch bearing if it quits when the clutch is out.
Old 12-10-2013, 11:37 AM
elevenbravo78
before I pulled it apart, I took just one more look at the clutch and realized I had installed the adjuster plate bolts on the "c" (lowest setting) so I moved it to setting "a" and took a 20 mile test ride. Seems perfect, but like I had said before, it was hit or miss sometimes. So I'll take it out later today and test it again. If this isn't it, I'll proceed to taking the primary completely apart again. Figured it was worth a shot at double checking the clutch before I go taking everything out. I'll let ya'll know what I find out.
Old 12-10-2013, 06:30 PM
elevenbravo78
to answer the last above question...yes it only does it when I release the clutch. I didn't get a chance for another test ride this afternoon. Tomorrow, weather permitting I'll give it another shot. I have heard the groaning sound a few times when I've kickstarted the bike too. You might be on to something about a bad bearing. I'll let ya'll know tomorrow. thanks for all the replys.
Old 06-20-2018, 09:03 AM
NotAknucklehead's Avatar
NotAknucklehead
NotAknucklehead is offline
Resurrecting an old old thread! Noticed my 14 FLHTK doing exactly same thing, and this thread showed after a search... Wondered what you ultimately found..
Iron lHorse
08-06-2017 08:46 PM
GlobeWarmer
10-12-2014 11:22 AM
tonebone_79
05-19-2014 10:03 PM
Catmanjoe
Exhaust System Topics
07-30-2013 12:37 PM
SportsterSnow
06-14-2013 09:14 PM
Quick Reply: groaning sounds coming from primary...
