inner primary seal
inner primary seal
Hey everyone,
Just had a question about the oring that goes between the inner primary and the engine. It looks like there was some silicone around this oring. Is this normal? Should I just be able to replace the oring and skip the silicone? Im replacing the 2 seals and the oring as the inner primary seal was leaking. Btw this is on a 94 heritage.
Wild
Wild
I did this already this summer and it was not that big of a job. I have no leaks and there was no evidence of silicone from the previous owner so I added no silicone and have been good so far. Thank God!
tips
1. If you decide to remove the clutch hub basket that is a 1 3/16 inch left hand thread socket, was in my FLTR anyway.
2. 175 lbs of torque is fairly important but I must add that you should only use the red loctite sparingly when reassembly comes. John from Mia, a person we should all listen to, will advise you on this when the time comes. BTW, this is for the 1.5" nut on the compensator. Again, it is on my '98 fltr.
3. This is the absolute bestest time to carefully inspect your charging system. Look for Dr. Hess's sticky about that.
Good luck and I hope this helps,
Tom
tips
Tom
@miacycles, Im in the process of cleaning everything up today and don't plan on using any silicone. Didn't think I needed it which is the reason for the question.
@Tee&Vee, Thanks for the info, I didn't even think about checking the charging system, so add 1 more item to the list. lol
@Ken Oaff, Never thought about loosening those items off before reinstalling the inner primary, but will definitely do that as that sounds like some insurance against having to buy a new one.
Thanks guys
wild
Thanks guys
wild
Look at a TC tranny and how it mates to the crankcases and you'll see how much metal was required to stiffen the set up.
renlan
05-08-2023 09:29 AM
JustDave71
11
04-12-2010 12:14 PM
