slightly notchy front fork bearings fix
I just got done changing tires on my 99 Softail Custom, and while I had it on the jack I checked the front fork fall away. It seemed a little notchy when straight ahead and moved right or left from there. Since it has never been greased at least for the last 24,000 miles I got a tube of fork grease from the HD shop and gave them a good greasing. It pushed out a lot of hardened old grease before the new stuff started coming out and when I finished the notchyness was gone. It feels very smooth from full left to full right. So if you have not greased your fork bearings for some time it might be a good idea to give them a good greasing.
Received 4,361 Likes
I just used the grease gun on the zerk in the neck. I don't think it had ever been greased as it took quite a bit to fill up the neck before it started pushing the old grease out. It even feels better when I am riding, but that could also be to the new tires. It just feels more solid and smoother. I guess that zerk is there for a reason.
There was a hole but no fitting.
I was just curious how you did yours.
True! Checking again after a decent ride will be interesting, to see if the newly introduced grease has been pushed aside and the notchiness has found its way back.
I have ridden about 200 miles since I greased it and it is fine so far. I did use Harley's special neck grease and with the cool weather now I don't look for it to leak out till next summer. I still think it was from dried out grease in the bearings as the notchyness was almost imperceptible. Time will tell I guess.
