FXR: What years are best?
1990 had bad cases that tended to crack
92-93 had inferior camshaft bearings
both the above should be fixed by now
early evos had 5 piece crank, later evos 3 piece crank
there is a school of thought that the earlier cranks are better and made of better quality material - but others will think other wise
personally I'd by pre 88 and get the earlier crank, but then I'm biased and have a 86 glide that's been around the clock a few times and the bottom end has never been apart
O’Malley the Alley Cat (07-30-2022)
I've always been impressed with the FXRs. Best handling chassis MoCo ever built. Be aware, the FXR models came in different flavors, with different rake angles, depending on the model. If I remember correctly, the FXR had a steeper rake than the FXRS. Among the many models were: FXR, FXRS, FXLR, FXRP, FXRD, FXRT, FXRS-CONV, and the CVO versions, FXR2, FXR3 & FXR4. (I may have missed a couple in there somewhere).
Put over 90 kmi on my 1991 FXRS that ended up more an FXRT than an FXRS by the time I got done changing things up to get it where I liked it.
I could be wrong, but I remember HD specs of 29 degrees rake & 31 degrees rake for different FXR models. Kinda like these specs in the attached. I know suspension parts are different lengths, so (I'm understanding) those rake angles are strictly suspension related and not due to differing frame geometry? Never looked at it that way before, but I hear what you're saying.
Real good info here guys' thanks for your posts. That's exactly the kind of information I was hoping to get. Many thanks, and keep them coming in. I did a search prior to started this thread and wasn't able to find anything specific to the differences in FXR's. So I'm sure others will benefit from your input as well.
Thanks again, it's appreciated!
If you buy an fxr buy a later model they have a better transmition splined shaft. Is the best I own a 1990 fxlr and a 1992 fxrs-sp both are bad *** and I can’t complain the LR I raised in the back put 13 inch shocks in the back +2 in the front changed the wheals to 9 spoke mags put p bags on it and a full fairing and put a 88 inch S&S motor in it bike is a beast I love it the sp is mostly stock minus the bars seat and pipe I love them both u can’t go wrong with either fxr is still the best bike around oh I got floor boards on the sp and mids on the LR. IF U GET ONE U CANT GO WRONG
1990FXLR
