86 liberty classic starter problem
Hi all
New guy here in need of some help. I have an 86 liberty classic that's having starter issues. Starter spins solenoid kicks out like it should but I hear a whine and it won't turn over. If I keep hitting the start button sometimes it ll catch and start. Could it be the starter drive gear unit?. Pulled the starter and the small splines on the starter itself look good as does the larger gear that the splines go into. Pulled the primary cover and watched the starter gear engage on the flywheel but didn't turn it over. Thank in advance
Matt
Matt
Received 4,361 Likes
Sounds like you nailed it...buy a quality replacement...lots of junk out there.
starting
Hi all
Matt
Matt
Agree with other poster, the starter clutch(Sprag clutch)is toast. Depending on how old the starter is its probably better to replace the entire starter than rebuild it.
if armature windings and field windings still ok, new carbon contacts and clean armature up as per workshop manual its probably better than the Taiwanese replacements that are being sold
