Base gasket oil leak
Old 10-09-2013 | 05:08 PM
TheBanditColorado's Avatar
TheBanditColorado
Default Base gasket oil leak
My base gaskets have started leaking a bit. Enough to show up on the cam cover after I ride. Annoying but doesn't seem to affect engine performance yet.
I don't want to crack it open or replace them right now cause I'm too busy riding it. Will I be okay for a while ya think?
When I get in there I looked online and saw a thing called "The" Oil Fix basically a hollow plug for where the cylinders meet the crank case. I think it makes a tunnel for the oil to go through so it cant leak out even if the base gasket sucks. It looks like a good solution though looks like a pain in the *** for a hack mechanic like myself. Maybe just warm it up extra carefully and cross my fingers that it doesnt get worse.
Bike has 55,xxxc miles on it.
Old 10-09-2013 | 05:19 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
What you are describing sounds like a seep.
I wouldn't worry about it for now.
Old 10-09-2013 | 05:21 PM
bluharley's Avatar
bluharley
I rode with leaky base gaskets for about 30k. When I changed my base gaskets because I didn't like the leak, it started cascading problems. While I had the jugs off, I "tightened" up the top end, then I figure the tight top stressed the crank pin and it failed, bottom end rebuild. Maybe that's all bs, but that's how it went for me. There is only crank case pressure at the base caskets, it doesn't effect compression or anything else. I wonder if I had just let the bitch leak, it would have been quiet.
Old 10-09-2013 | 05:46 PM
Yankee Dog's Avatar
Yankee Dog
If your running synthetic, then consider conventional oil. It may stop leaking after a couple hundred miles...mine did. YD
Old 10-09-2013 | 05:53 PM
TheBanditColorado
Running HD 5. Which is conventional oil I was told so that isn't the issue unfortunately.
Old 10-09-2013 | 06:19 PM
jsbridgew's Avatar
jsbridgew
the hayden oil fix kit or the piglets (don't think you can get those anymore, though) work well... i've used both
Old 10-09-2013 | 06:27 PM
bluharley's Avatar
bluharley
They do make much better gaskets these days, although I think HD will still sell you .025" paper gaskets so you can do them again in 10 years or less. I have metal now.
Old 10-09-2013 | 06:45 PM
HarDlife's Avatar
HarDlife
It will run perfectly fine as long as there is oil in the engine.
Old 10-09-2013 | 11:48 PM
cowboy 51's Avatar
cowboy 51
Mine have been seeping about a year now ,But both me & the bike have been down about 4 months ,But I still put a little over 18k miles on it , just check your oil ever once in awhile ,I keep wiping it off so I can keep a eye on it
Old 10-10-2013 | 12:09 AM
TheBanditColorado
Thanks thats what I'll do
Quick Reply: Base gasket oil leak
