Rear brake rotor
Received 4,361 Likes
That's because you have the remote reservoir type of master cylinder and they don't have a second hole.......what you need to do is pull the cylinder body apart (its real easy) and give it a thorough clean up.
The overhaul kit is usually a cartridge with all the seals and stuff on, you just slide it in with a generous coating of brake fluid but clean it up and flush the line to the reservoir.
So I do need to get the master cylinder rebuild kit from Harley?
HamToast
03-18-2015 12:23 AM
