Oil pressure issue
Oil pressure issue
I posted this in the tech forum but no such luck. Will try it here.
I have an Ultima 96" evo based motor. I bought it completely disassembled from a friend. He said the motor never showed oil pressure. He had 3 different oil pumps on the motor. He replaced the light sensor on the motor and the light would never go off going down the road. He replaced the sensor with a direct mount gauge and the gauge would never show pressure. The cam cover was also replaced on the engine and still no change. I purchased the engine completely disassembled. All bearings and bushings and seals appeared to be in perfect condition. I had the bottom end built by a reputable builder and he said everything looked good. When I put the engine together and in the bike it will hold oil pressure while cold and still no pressure while hot even when reved up. I looked in the tank while the bike is running and had good oil return. Do you have any idea as to how I can fix this problem?
the main noise i am getting is valvetrain noise toward the rocker boxes. I pulled the tappet screen last night and everything was clean. the oil pump is new. and everything appears to be good. I even collapsed the back pushrod tube after the motor warmed up and started it again and it had oil dripping down from the top. I did not let it run very long like that as i did not want to destroy anything just wanted to see if she had oil.
