Dirty Pictures..............
#31
#32
rockher_man (04-30-2020)
#33
#34
Received 4,361 Likes
#35
A stumble when you blip the throttle usually means you need to adjust the accel pump screw. I didn't read where you adjusted that. It's easy, just check the s&s website for instructions. Start with the screw all the way in and work your way out 1/2 turn at a tme. If you see any black smoke when you blip, the screw is out too far and will stumble as well.
Also did you put a new pump plunger in? They get cracks in them. If you get two good squirts of gas when you blip it your plunger is proly OK.
#36
Nope, didn't do anything to the accel pump, but, since I found this cool store with all the parts, I think I'm going to rebuild it.
The rubber boot was all cracked. Will that cause an operating problem?
#38
#39
