Tell me why, and i know I've asked this before.....
Received 4,361 Likes
That's the pump that squirts fuel when I twist the throttle, right? I looked into the carb the other and twisted and it squirted. How do you tell if it's "bad?"
Idle jet requires removal of the carb ,correct? What size should it be?
Depends on what year your carb was made.
Post 2004 (like mine) I have had good luck with the .0295 jet.
Pre 2004 you have to ask Dr Hess.
You don't have to remove the carb just the bowl.
You have a S&S carb, right?
You might just need a pump adjustment, or in your case, you might have something like this going on.
Last week I repaired an accelerator pump on a super E
The carb was 2 months old.
10% ethanol gas was used since the carb was installed,,,,but,,,
also four tankfulls with SEAFOAM added was used right after the carb install.(bike owner loves seafoam too)
The diaphragm was ate up, and when it started letting gas up to the bellows, it got that too.
coincidence?
coincidence?
coincidence?
coincidence?
What does THAT tell me? Running too lean?
Dang, that hurt......I only used SEAFOAM in her ONCE, and it was 1/4 cup to a FULL tank of gas.......
Well, tonight, I tried an experiment. She was running rougher than usual, so I barely, and I mean BARELY pulled the enrichener and she smoothed right out.....she was warm BTW
