Lazy kickstand
Old 08-29-2013 | 12:03 PM
Slammed-N-Senseless's Avatar
Slammed-N-Senseless
Ok, this is purely a guess as I've never had to really mess with one but it looks as though the arm has an awful lot of play in it. Can the top bolt be tightened? maybe it's just too loose. Or, you can get a whole new assemble from JP for about $60.00, a small price for the safety of a kickstand that won't fall down
Old 08-29-2013 | 12:26 PM
RidemyEVO's Avatar
RidemyEVO
Guesses count too and can be helpful. Nut is already torqued as far as its suppose to go but yes I too feel that the arm is awfully loose, I'm just not sure whether its from a worn out kickstand or spring problem or what.I have no problem buying parts.
Old 08-29-2013 | 12:38 PM
moog5050's Avatar
moog5050
Just replace the whole assembly - small price to pay for safety. That could be a major accident waiting to happen. Good luck.
Old 08-29-2013 | 01:22 PM
RidemyEVO's Avatar
RidemyEVO
Anyone have the proper oem number for the kickstand assembly and spring for my 89 flhtp?
Thanks
Old 08-29-2013 | 01:29 PM
Schex's Avatar
Schex
Originally Posted by RidemyEVO
You think so? I'm not home right now but ill definitely have a look see . I take it they just glue on? Will this give more spring to the kickstand?
If you got time perhaps you can post a pic of proper location?
Thanks a bunch
Might not be your whole problem, but it just pulls off.
Old 08-29-2013 | 01:37 PM
RidemyEVO's Avatar
RidemyEVO
Thanks I just got home and take a look right now , try moving it back.
Old 08-29-2013 | 03:17 PM
Slammed-N-Senseless
Here you go:
http://partsfinder.onlinemicrofiche....D--JIFFY-STAND
Personally, I don't know if there's an advantage for buying OEM or a jiffy stand assembly from JP but others here may be able to shed more light on that.
Old 08-29-2013 | 03:44 PM
RidemyEVO's Avatar
RidemyEVO
Definitely was too far forward, probably got push putting the jack under. It stops on the bumper now but didn't make any difference. Good thought though.
Old 08-29-2013 | 04:20 PM
RidemyEVO's Avatar
RidemyEVO
Can anyone see any reason why the kickstand setup off a 1993 flh won't fit mine?
Old 08-29-2013 | 04:24 PM
RidemyEVO's Avatar
RidemyEVO
Here you go:
I can only find for a softtail.
Quick Reply: Lazy kickstand
