voes and RPMs
Very doubtful. More likely a carb issue. What bike, what carb, what cam, what mods, what is "high rpms"? The stock ignition module cuts out at a certain RPM as the rev limiter. Without the rev limiter (different ignition,) they will all cut out to some extent when the lifters pump up and you float the valves.
