How tight does an oil fiter have to be?
Old 08-09-2013, 08:53 PM
traildog's Avatar
traildog
traildog is offline
Default How tight does an oil fiter have to be?
I had to punch 3 holes in the one that was on Scarlett so I could stick a BIG screwdriver in it to turn it, and even THEN it was a BEOTCH to get loose......Bertha's filter had a nut on the end.......SOOOO easy to remove.
I WAS going change all 3 fluids, but, the oil filter had me so pissed, I thought I better wait until tomorrow to finish the other 2.......
Old 08-09-2013, 08:57 PM
QC's Avatar
QC
QC is offline
Received 19,803 Likes on 9,866 Posts
Not that tight!
cowboy 51's Avatar
cowboy 51
cowboy 51 is offline
Darn that was way to tight ,I just wet the O ring with fresh oil & hand tighten never had a leak
Old 08-09-2013, 08:58 PM
Sharpie's Avatar
Sharpie
Sharpie is offline
Thats why I use the K&N filters. I like the 17mm nut on the end ofthe filter. No special filter wrench is needed. Just a 17mm socket and a ratchet with an extension. No needto have to destroy the filter to get it off.
Old 08-09-2013, 08:59 PM
Tee&Vee's Avatar
Tee&Vee
Tee&Vee is offline
k&n 170c has a 17mm nut. i like 'em lots
Old 08-09-2013, 09:05 PM
traildog's Avatar
traildog
traildog is offline
I put the new one on hand tight.....Sheesh, I think the shop used a MACHINE to install the one I removed!
Old 08-09-2013, 09:27 PM
Wild Card's Avatar
Wild Card
Wild Card is offline
13ft lbs.
Old 08-09-2013, 09:30 PM
2black1s's Avatar
2black1s
2black1s is offline
A good rule-of-thumb is to tighten an additional 1/2 to 3/4 turn after the gasket makes initial contact.
Old 08-09-2013, 09:33 PM
traildog's Avatar
traildog
traildog is offline
THAT'S what I did........
BC45's Avatar
BC45
BC45 is offline
Most car filters say 3?4 turn past after seal makes contact, And lube seal with fresh oil before installing
Quick Reply: How tight does an oil fiter have to be?
