Evo carb
Evo carb
Ok carb guys need some help. Got a 94 dyna that hasn't ran in 5 years. Got her cleaned up, and pulled the carb to clean it up. Man was it nasty! Anyway got her put back together fired her up and what do you know she is running! Problem is will not run unless choked and the overflow for the carb is steadily leaking gas! Is it getti g to much fuel? I know I know I need to rebuild carb but for right this minute just trying to get running. Thanks for the help!
Received 4,361 Likes
Im not sure what you got going....you say just about got it running...does it idle...or does it quit?
There is a idle adjustment screw on top...near the back...you should be able to see it...has a spring under it....kind of under the tank...hard to reach.
That adjusts the idle....depending on the carb...turn it right to speed up the idle.
Running with the choke on is normal if its still cold also....
Ok stock air cleaner, after market pipes ( not sure what brand), when I had the carb apart one jet said 165, not sure the other jet. Bike had been running about 10 minutes half choke but still wants to die when choke it off. You will have to excuse me I am not a carb guy just working on a bike for a friend
First thing would be to find out if it ever ran with that carb setup/jets etc. If yes then you need to determine if it is running rich or lean. Sounds like it is leaning out when you take the choke off. Leaking overflow indicates stuck float/needle and seat. All of these issues would make me pull the carb and do a complete rebuild. You need to figure out what jets over stock if any are needed for those pipes and go from there.
