Spyke or Compufire Coil
Is the Spyke coil any better than a Compufire coil when running a Compufire ignition.
The Spyke advertising states up to 80,000 volts and Compufire states 45,000, if either is true.
My current Compufire coil works fine, but I got to wondering if I might benefit from the Spyke. Also got to wondering if the Spyke was compatible, might 80,000 volts produce excessive heat, or damage the ignition, etc.
Your thoughts appreciated.
jizquie560@aol.com
08-12-2009 03:19 PM
