Single fire wires to coil
May be a dumb question but..... I just got my motor back together after doing base gaskets n head job. I see my coil isn't marked F n R for spark plug wires. Does it matter which plug goes to which coil "inlet"?? I checked my kids Twinkie and his coil is marked F n R. Just wandering if the wires are on wrong plugs what would happen?
1989 FLHS Dyna single Samson true duals, pretty much stock
Thanks in advance,
Mike
Thanks in advance,
Mike
Thanks in advance,
Mike
Thanks in advance,
Mike
How did this get so off?
Dang that's the only tires I run!! Gonna hafta check em out and keep an eye on them. Thanks for the infoThe OP has a single fire ignition and wants to know where the plug wires go onto the coil! A single fire coil is different than stock.
I will check tomorrow, but I believe the front wire goes onto the left, and the rear goes onto the right.
With a single fire coil you have to have things right.
With a stock coil it doesn't matter.
Bobby-b (10-11-2024)
Woods Glen
10-23-2010 07:52 PM
