Dying engine
Old 08-08-2013, 05:25 PM
miacycles's Avatar
miacycles
miacycles is offline
Have you unhooked the power wire to the coil and tried a jumper to the terminal???? If not do that first. It will rule out an intermitent power problem. Don't just throw parts at it in hopes of finding the problem. Diagnose, repair, ride!!!!!!
John
Old 08-09-2013, 01:50 AM
splittie65's Avatar
splittie65
splittie65 is offline
Miacycles thanks for your suggestion......however as I pointed out, when I did some testing whilst not working I had power to the coil, yet there was no spark. A jumper would have made no difference.
Old 08-09-2013, 05:44 AM
Hackd's Avatar
Hackd
Hackd is offline
Okay... I'll play:
Have you checked all the grounds? Sounds to me like you've got an intermittent open circuit. Either bad ground, or bad wire somewhere. Could also be loose connection at breaker(s).
Old 08-10-2013, 09:49 AM
splittie65's Avatar
splittie65
Checked all the grounds and cleaned them.
Had the connectors apart and put back together. All looked OK.
Think there is only one breaker on the '95 model....and if that was no good the starter wouldn't work.
As the last time it wouldn't start.....while it was still playing up I checked the voltage on the connection to the coil and there was 11.4 V......yet no spark.
I took the plunge and got a new coil (I know, I know, don't throw money at new parts), and since then have done two 12 mile trips with no break downs.
I suspect the bike is lulling me into a false sense of security! But maybe....... )
Old 08-10-2013, 01:06 PM
JohnnyC's Avatar
JohnnyC
JohnnyC is offline
Glad you were able to get it going!
Coils go bad? (J/K)
BTW ... above, I was posting about the module while you were posting a replacement didn't make any difference. I'd rather pay the price for a coil set than an ignition module.
Some day, when you do need it ... you would really like an upgraded aftermarket ignition module.
EDIT:
It'd be nice to always find the bad part first off but the theory of starting with the least expensive part it could be sometimes pays off and sometimes cost you.
And with an older bike, throwing parts at it is never a (real) waste. You now know the condition of some critical components is in new. I consider it an investment. LOL (that's if you have the money, and if your planning on keeping the bike).
Old 08-10-2013, 01:26 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
You can be successful throwing parts at it till it's fixed but it is unlikely.
Sounds like you managed though.
Glad you got her running!!!!!!!!!!!
Dirty_diesel
06-18-2019 08:15 PM
Stella456
03-24-2012 05:45 PM
tmac
08-07-2010 08:00 AM
zeus33
Electrical/Lighting/Alarm
04-13-2009 12:05 AM
trook
06-14-2007 04:43 PM
Quick Reply: Dying engine
