S & S carb install 1984 FXRS-breather tube location?
Old 06-29-2013 | 10:15 PM
Hank Johnson's Avatar
Hank Johnson
The backing plate that the air filter attaches to has a threaded through-and-through hole that has a nozzle fitting you screw into the back of that hole that accepts a hose. That hose is supposed to go "to the crankcase". If I'm understanding you correctly, I should plug that fitting? BTW, I did find a crude schematic in the factory guide like you suggested. It shows the oil pump with a tube traveling up to the air cleaner called "crankcase vent". What and where that "tube" is and how to join or get it into the crankcase and what hole in the crankcase-is still a mystery to me. I prefer your rec to ignore or plug.
Old 06-30-2013 | 06:36 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
In your case plug all holes in the air cleaner back plate to make sure all the air going into your engine is going through your air filter.
Old 06-30-2013 | 06:52 AM
Dr.Hess's Avatar
Dr.Hess
Yeah, plug the hole. The hose from the crank case should point down (and not be plugged, of course).
Old 06-30-2013 | 09:30 AM
Tom84FXST's Avatar
Tom84FXST
If you connect the hose to the air breather, at some point you will have at least a 1/2 quart of oil on your leg when the engine wet sumps...it will happen. The hose connection to run to the ground is in red.
Old 06-30-2013 | 04:04 PM
Hank Johnson
Thanks to your help (that picture), I found the breather. It projects rearward on the horizontal and is just an open hole. Unfortunately there is only about 1/16th inch of threads protruding from it, so there is not an easy way to attach the breather hose to it.
So having found that it is venting at the case, and not finding an easy way to connect the air filter to it, is it your opinion that I should block all holes coming out of the S & S back plate including the metal breather elbow screwed into the carb back plate?
snowboarder
01-27-2018 05:34 PM
Pthom
EVO
48
10-14-2014 09:22 PM
LouisB
02-19-2013 11:49 PM
98glider
Ironhead
17
04-07-2008 03:56 PM
painxxx
Exhaust System Topics
07-04-2006 06:32 PM
Quick Reply: S & S carb install 1984 FXRS-breather tube location?
