Thrust Washer
Thrust Washer
When changing the cam, I've heard it is a best practice to press the original cam gear onto the new cam, but what about the thrust washer? My original one measures .63, it looks pretty good (20K miles on it). I'm wondering if it is a best practice to use the original one of should I go with a .60 or .65 which are brand new?
you need to measure for clearance.
reuse your old gasket, and snug at least 3 bolts on the cam chest. now, through the lifter block hole, measure the endplay on the cam. when I did mine (all 5 times lol), i shot for .010" endplay (back and forth movement on the cam between the case and cam cover)
i used my fingers...but that works too.
works two-fold.
you check the endplay for clearance (like i said, i shoot for .010"), and that you've got a bit of "wink" in the gear engagement. you dont want it sloppy loose, and you DEFINITELY dont want it so tight that its binding (this is why many people press their stock cam gear onto aftermarket cams)
works two-fold.
