Harley EVO breather gear install
06-25-2013 | 08:41 AM
Can someone please confirm that as I am replacing the breather gear from the stock plastic one to an S&S breather gear that I need to match up all the timing marks as I have done in the picture.
The only thing that has been changed is the breather gear.
Anything else I need to look for before I put it all back together?
Thanks
06-25-2013 | 09:50 AM
U need to put a gasket on it and check end play for the correct shin if you haven't done so already, chad
06-25-2013 | 10:15 AM
the marks do look right, but if you went with S&S anyway, why didn't you buy a reed breather from them?
06-25-2013 | 10:38 AM
Looks good just do as 96 says......
06-27-2013 | 05:52 AM
Quote:
Originally Posted by
jokenroll
Thanks for the replies. I did not know there was a reed breather available or else I would have used one of them.
06-27-2013 | 06:58 AM
tonycap
Your good, S&S says reed breathers are not compatable with bottom breathers.
cyclepath37
EVO
05-08-2017 04:33 AM
Bumpandrun
EVO
03-12-2013 01:58 PM
gsxrboy96
EVO
05-10-2012 07:19 AM
mbierbac
Exhaust System Topics
02-06-2012 02:20 PM
Avocado
Shovelhead
10-01-2006 01:00 AM
