Fork oil?
Received 4,361 Likes
OP You should use the DRY amount of fork oil if you rebuilt your forks.
How exactly does measuring the height tell you if the quantity is correct if the service manual specifies the quantity only?
the service manual on my 2010 fxd specifies both (measurement and fl. oz). I went off the measurement because the progressive springs I added were bulkier and displaced more oil than the oem
Do your forks have a sight glass or do you insert a stick or wire into the forks and where does your manual say the measurement should be?
Because you haven't seen it doesn't mean it doesn't exist.
My 2009 Touring Model Service Manual PN 99483-09 page 2-54, table 2-18 specifies Fork Oil Requirements as 10.7 or 11.0 ounces (quantity), 317 or 325 milliliters (quantity), 4.92 inches (height) and 125 millimeters (height).
The service manual specifies the tool to be used as PN HD-59000B or you can purchase the Motion Pro version cheaper.
http://www.motosport.com/dirtbike/MO...IL-LEVEL-GAUGE
Coming off of 40 years of dirt and sport bikes, suspensions are important for me. I am not satisfied with "good enough" or "it's always gonna clunk".
Your tool looks like the stick down the fork guess was the right one.
