Fork oil?
Old 06-10-2013, 08:00 PM
Juan L's Avatar
Juan L
Juan L is offline
Moderator
Received 20,117 Likes on 10,260 Posts
Originally Posted by texashillcountry
Believe it or not my last post was not sarcasm but true curiosity.
Your tool looks like the stick down the fork guess was the right one.
I didn't mean to convey an a**holish attitude, sorry.
Yes it is a stick of sorts that is graduated and the point is to overfill past your desired mark then stick the tube down into your forks after setting it up to the desired height and draw off the excess with the syringe. Works flawlessly every time and really helps get your levels right so you can get your forks setup properly.
Old 06-10-2013, 08:08 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
I wonder if there is a difference between the TC forks and the EVO forks.
What I mean is Can the measurements from a TC be used on an EVO?
I do know that the service period for EVO forks is shorter than that of the TC.
Old 06-10-2013, 08:14 PM
Juan L's Avatar
Juan L
Juan L is offline
Moderator
Most of the forks I have ever worked on fell into a range from 115mm to 155mm from the top. The measurement is not an absolute, it really lies in what type of spring you have in there and what length your spacers are to get the correct sag, free and loaded.
Old 06-10-2013, 08:23 PM
texashillcountry
Dirt don't hurt
So basically without a reference number the measurement method is of no use on an EVO.
Is that what you are saying?
Or are you saying just take a guess from 115-155mm?
Old 06-10-2013, 08:36 PM
Juan L's Avatar
Juan L
Juan L is offline
Moderator
If it were me, I would check a newer version of a service manual to see if there have been numbers assigned. In the absence of any other reference I would start conservatively by setting the level at 130mm. I am not sure how this relates to the quantity method of measurement on your specific model but the measurement is taken with the spring in the tube and with it completely compressed. This should leave plenty of air in the tube and if anything will make it very soft. Your mileage may vary. You can then set it 5mm at a time to get a good setup. Remember too much fork oil and it will lock as there will be no room for it to flow and create the damping action. The other very important factor to consider is the viscosity of the fork oil AND the types of valves you have in the forks.
Old 06-10-2013, 08:40 PM
ynots's Avatar
ynots
ynots is offline
Originally Posted by Spanners39
Use the amount the manual says, it will be fine. If the progressive springs need a different quantity it will say so in the installation instructions....and yes, its a long way down :-)
Progressive tells you to reference the service manual lol
Old 06-10-2013, 08:48 PM
Juan L's Avatar
Juan L
Juan L is offline
Moderator
Since your new springs displaced more oil than the old ones you had no choice but to use the height measurement as your reference. Did you adjust the level one way or another to get the feel you wanted?
Old 06-10-2013, 08:58 PM
ynots's Avatar
ynots
ynots is offline
Just out of curiosity how do you check your measurement?
Do your forks have a sight glass or do you insert a stick or wire into the forks and where does your manual say the measurement should be?
You measure from the top of the fork to the top of the oil level while the tube is vertical and the slider is compresses. HD makes a gauge pn. 59000A for the challenged, You need to slowly pump the slider 8 - 10 times to exhaust the air. FXDC / FXDL, FXDB, is 3.74 inches, FXDF 6.18, FXDWG 3.74
If I was going to adjust anything it would be by changing the weight of oil, I stayed with type E. At reccomended level... For now anyways
LeavenworthJeff
04-23-2015 06:28 PM
AllenW
05-13-2012 09:29 PM
ChromeJunkie
06-15-2009 10:35 PM
alank
12-09-2008 09:02 AM
Jinxie
Oil Archive (no new posts)
02-20-2008 10:36 PM
Quick Reply: Fork oil?
