oil leaking out breather tube.
got motor put back in after painting frame and got bike ready to start and turned over a few times. then i noticed a good amount of old oil coming out the breather line that comes off the case. is this just old oil from sitting?
I find it odd the fresher the motor is on mine the more it gargles and pukes out the breather,when its getting close to needing a little love it almost stops.Mine is cammed and fairly high compression and gets rode hard to show a lot of the 103 inch twin cams what a real harley is about so it needs a little more frequent love than most.
Dont be tempted to add oil if its low on the stick and its set a long time as it more than likely is hiding on the bottom side and will hark a bunch out but return some back to the tank
travistodd1
Exhaust System Topics
01-10-2014 11:26 AM
