fuel line help 1987 flhtc
first off im working on my fathers 1987 flhtc and I removed the fuel tank to clean the engine. well in my haste i didn't look hard enough at where the rear fuel line goes and i cant find any open spots where it might go. the book only shows the rear fuel line but i cant find where it goes. i searched the forums and got nothing. i looked on my 1992 and it dies not have this fuel line on it from what i can see. any help would be appreciated.
If it's anything like my '88, the line coming out of the back of the tank is just a vent. I just run my hose down to the ground in case a full tank expands, the fuel has a place to go. I think that's what it's for, but that's all I do with it. Sometimes I've forgot to hook that hose up, nothing happened.
Received 4,361 Likes
Depending on model some bikes, including my 1990 FLHS, have two vent pipes, one for spillages while refuelling, the other for expansion. Both are on top of the tank and go down under the nose of the seat to the ground, as bluharley says. I run mine to the right side, away from the belt, behind the trans.
