LBs compression for 10.1 pistons
ev 27 with 10.1 and it starts very easy. no pings. Im just kinda worried about head gaskets with 2oo lbs compression Whats the best head gaskets these days?
220 starts getting into detonation area in heat.
Cometics MLS are hard to beat.
If it is starting good and no detonation in 90 degree weather then you are ok, If the starter bounce gig comes in then you have an option to go with a later intake closing cam to let some air out of it. EV27 is at 36, Woods 6 is at 40 and W8 is at 47 so you can control cranking compression if the EV27 becomes a detonation monster in heat. Head gaskets havn't been a issue with the technology provided, been at 10-1 with a Woods W6H (40 intake) for years and don't cut it much slack using Cometics.
cruzmisl
Exhaust System Topics
13
09-24-2012 06:23 AM
