Bertha's new owner got back to me.
Old 05-13-2013, 07:14 PM
traildog's Avatar
traildog
traildog is offline
Default Bertha's new owner got back to me.
He must have been cranking the starter too long. Dealer shop told him he burnt the starter clutch and "chewed up the starter clutch hub."
I'm going to have to look the hub thing up. Not sure what that is, but dealer is charging $900 to fix it.
I think you can buy a whole new starter and install it yourself for a LOT less than that.
Oh well, I feel bad for him, but she was running and starting beautifully for me when he rode off on her.......
BTW, Bertha had a VERY specific way she liked to be started. Twist the throttle (once) and let off, pull the enrichener, and push the button. Worked EVERY time!
Is that the way you all start your EVO's?
Old 05-13-2013, 07:17 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
IAMSWUTIAMS is offline
Lot of money for a starter.
Old 05-13-2013, 07:34 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,361 Likes on 1,953 Posts
I think whole starters are like $250.
That means the dealer is charging him $650 to change it.
Tell him you will fix it for $300!!!!!!!!!!!!!!!
Old 05-13-2013, 07:41 PM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 20,134 Likes on 5,827 Posts
I am sure the ring gear is what is damaged...but it is rivited to the hub...they are going to replace the whole thing.
Old 05-13-2013, 07:54 PM
traildog's Avatar
traildog
traildog is offline
Oh crap! THAT does look like a lot to fix......Betcha I could do it though......
Old 05-13-2013, 08:02 PM
ironoxide's Avatar
ironoxide
ironoxide is offline
Sounds like Bertha don't like new partner...women!
Old 05-13-2013, 08:04 PM
Tom84FXST's Avatar
Tom84FXST
Not that tuff a job...but that part alone from Harley is $389...add starter clutch, gaskets.oil etc etc...$900 is not that out of line from a dealer
Old 05-13-2013, 08:10 PM
traildog's Avatar
traildog
traildog is offline
Yea, I just looked it up. But. how the heck does the ring gear get chewed up?
Old 05-13-2013, 08:50 PM
Schex's Avatar
Schex
Schex is offline
Received 7,044 Likes on 1,857 Posts
double post
Old 05-13-2013, 08:55 PM
Schex's Avatar
Schex
Schex is offline
He needs something like this
http://www.jpcycles.com/product/380-594
Remember that ignition relay I talked about?, gonna keep spinning the starter to death when the battery gets just a little low, the DTT ignition does not like to fire if voltage supply to module drops below 9 volts.
Sad part is after $900, the root problem will still be there
Should not need a trick to start,
turn on fuel, pull choke, hit start.
He probably should change that petcock too.
Quick Reply: Bertha's new owner got back to me.
